Any one have a base map for Ls2 24x crank 1x cam ? im using link storm g4x with 2 lamda can. looking for trigger set up and gm stepper setting and can settings for o2. not worried about fuel and timing map so much. i have been looking around and not much info using link on gm v8s. Thanks Ken
Attached closest I have, from our LS2 race car. However ours is a later one with E-throttle and 58X trigger, so I have made some quick adjustments to give you a closer starting point for your setup. It has a CAN lambda connected to CAN 2.
Note fuel and ignition are mapped against throttle in this map and the tables start at 10% TP due to it being an E-throttle so that likely wont be perfect for you but it will still run.
Thank you very much , regards Ken
