MAF load sensing on two stroke?
703 Vistas
Gents
I am tinkering with implementing MAF based load sensing on two stroke motors, instead of AlphaN.
Reverse pulsation is a concern, can MAF be implemented at all?
Perhaps a plenum prior to the throttle body would smoothen out such pulsation?
What are your thoughts and, or, experience on this topic?
TIA
D
Reversion can be a problem on any engine - if not being used, I'd suggest checking "reed valve" options to see if there's a compatible valve for the engine. They normally widen and/or increase the engine's torque.
The other question is what metering method are you using, as some, like the spring loaded door (can't recall the corrct term ATM) type can have problems, but the "hot wire", while affected, should be mappable around any issues.
