Maf sensor location
2414 Vistas
Is it a problem to have the Maf sensor position just after the bend as in the attached pics... I'm doing a turbo installation on a toyota 86 and I'm trying to keep the intake pipe away from the turbo for heat reasons but not sure if this will be an issue for the Maf sensor because there not much of a strait line were its currently mounted. I haven't seen any other 86 turbo kit with the pipe running like myne and that makes me think it might be a problem.
Hello, George, there is no picture attached
Regards Ross
