Maf sensor position
1423 Vistas
Is it a problem to have the Maf sensor position just after the bend as in the attached pics ... I'm doing a turbo installation on a toyota 86 and I'm trying to keep the intake pipe away from the turbo for heat reasons but not sure if this will be an issue for the Maf sensor because there not much of a strait line were its currently mounted. I haven't seen any other 86 turbo kit with the pipe running like myne and that makes me think it might be a problem.
I had to repost this, as I could not get the pics to upload to the forum, so below is the link to the pics on google drive.
https://drive.google.com/drive/folders/1t7okCE_4h4QwTNj5lry4wTMl6g6h1-d_?usp=sharing
Hello i cant see it being a issue at all
Regards Ross
Thank you
