Megasquirt 2 weird issue cant find the solution.
822 Vistas
Hello,
Experiencing something realy odd here.
Mazda mx5 turbo megasquirt 2 ecu
Above 70kpa doesnt matter what rpm the injector pulse width is fixed and no longer response to the cell in the VE map.
I can make all the cells above 70kpa 0 or 255 and no response in fueling/injector pw /lambda valeu.
Below 70kpa i can tune the cells no problem.
Cant find a setting which could cause this.
Map limit is off, accel enrich is off tryd playing around with injector timing etc.
Any tips???
  • WhatsApp-Video-2024-11-27-at-10.32.00.mp4
Is the MAP sensor calibrated correctly? What does it read when the engine is stopped?
I think you will need to post your configuration for us to look at for any real help.
Have you asked for help on the MS2 Support Forum?
https://www.msextra.com/forums/viewforum.php?f=101
