Megasquirt
1701 Vistas
Hope I'm asking this question in the right section. I'm knew at tuning and am from the United States. I'm interested in the megasquirt system. Does all the courses here apply to that system as well. Thank you.
Hello yes all stand-alone ECU courses will be also relevant to Megasquirt also as they all have the same basic features inputs and out puts
Regards Ross
The principals of engine management are universal. Different ECUs with different software are just different versions of interface representing absolutely the same rules
The Practical Standalone Tuning Course has a Megasquirt MS3 worked example -- looks like almost 2 hours of video on the MS3.
