Methanol injection manufacture preferance?
932 Vistas
Hi everyone.
ive used Aquamist in the past with their fast acting valve. It has a small window of control for tuning it. I’m using Motec for driver. What are everyone’s thoughts on other methanol kits that are available? I’m shopping for my next project. Thanks for everyone’s input.
Russell
Aquamist has the best reputation in my area... Second to none.
Aquamist for a something you're laying on top of a pre-existing EFI setup, I've moved to fitting water/meth specific solenoids and using spare injector drivers for integrated systems.
I also like the Aquamist nozzles in terms of atomization, and I like using a number of small units vs. 1 or 2 big ones. Their flow meter is a nice touch, and their solenoids have worked well. I personally don't use the "kit" and control the pump and solenoids with the ECU I'm running the engine on, but their controller is also the best of the basic piggy back ones I've used.
