Mini DTM style connectors
1799 Vistas
I recall in a webinar a while ago, Andre showed some really small DT/DTM style connectors that used autosport pins and sockets. IIRC I think a 4 pin connector was equivalent to a 2 pin DTM.
Anyone remember what connector they were?
Are you sure he wasn't comparing DTM (mini DT) to DT? A DTM-4 is about the rough size of a DT-2. The #20 pins found in DTM are the same as the #20 pins used in Autosport connectors.
mega sure, cause I remember him talking about them using the autosport contacts.
my memory has been wrong before though...
