Missing Setup Wizard in AEM Tuner
2437 Vistas
Hello everyone.
Currently tuning a project of mine. Ended the day early due to a cracked exhaust manifold
Regardless I ran into an issue I think someone on here may be able to assist me with
The car is a sr20det s13
Car is equipped with AEM V2
Could not adjust boost at all no matter the settings.
It is currently wired into the PW2 pin on the ECU
The Boost Control wizard is actually missing in the Setup Wizard window
Anybody know how to retrieve that back?
Currently using the AEM MAC valve.
