Mitsubishi Colt 4G15T Mivec trigger issues - ECU Master
1221 Vistas
Hi... need advice to setup the trigger for a Mitsubishi Colt 4G15T Mivec. Attached is the ECU Master Classic base map we have started setting up and a scope of the trigger at crank. Any help will be much appreciated.
  • 4G15T-Startup-V02.emu
