Motec keypad to C127 dash
2489 Vistas
Hello,
i have a motec 8 button keypad, m150 ecu and a c127 datalogger wired on the same can bus (without a pdm)
I am running a gpr package in my ecu which supports the keypad so i already have 4 buttons controlling the boost and rpm limit.
I would like to know how to assign the rest of buttons to control the dash display mode and the reset channels in the c127 datalogger if anyone can support me
thank you
I would program unused driver switches in the M1/GPR. The Driver Switches are transmitted to the dash in the M1 Comms Template. You can then create some user conditions for the dash functions using those channels.
