Motec m800 hi/lo enable
2820 Vistas
Hello guys,
I have a motec m800 with hi/lo option enabled, but could someone explain to me how to put it on through the ecu?
Hi,
With the ECU connected to ECU Manager, Go to Utilities | Enable ECU Options... this allows you to enter the dealer supplied pass codes to enable the functions.
