multipoint 6cly Falcon
1254 Vistas
hi
I am about to start wiring up a Haltech elite 750 on a 1997 EL Ford Falcon. It runs a distributor ignition type setup. I want to run it in multipoint injection mode. How would I wire up the fuel injectors?
Thanks.
Hello, if running multi point group or batched injection you will need to pair the injectors as per the help file 1-6, 2-5, 3-4 using 3 injector drives or 123 456 using two injector drives.
Regards Ross
