Need assistance on selecting right ecu
1915 Vistas
Covid has put me in an spot where I need to be choosing an local manufactured ecu my choices is an ecu called dictator another one is powermod and bluearc another one probleem I'm having dew to alot of the big racers misleading the industry in south Africa I'm not getting an correct answer so I'm looking for an independent person that can look in to these an tell me with one would be the better ecu to run on my golf 1 with an abf turbo engine in it
if i was to pick i would go with the powermods ecu it seems far more developed
Regards Ross
Thank you as I dont understand the stupidity of south africans they like sheep need to ad you on my facebook and tag you in some discussions
i would rather not get into facebook groups I'm pretty happy helping through this forum thanks
