NTK Wideband sensor wire extension
2058 Vistas
Hi all!
Quick question… For fitment purposes, can I extend the wires from the sensor to connector? Will it upset the calibration?
Thanks in advance!
Nick
Hi Nick,
The wires on the NTK can be extended (the NTK connectors can also be removed/changed if needed, unlike the Bosch LSU sensors), just ensure that you maintain the same gauge of wiring. I would always recommend doing a free air calibration of the sensor if making changes like this.
Hi Stephen,
Thanks for your quick reply there! Great, I shall do that!
nick
