O2 Sensor Placement
2686 Vistas
Hey Andre,
Do you have any input on the placement of a WBO2 Sensor in relation to a Catalytic Converter. I have seen many people use a Tail Pipe Mount for their O2 Sensors, which is obviously Post-Cat. Wouldn't this affect their AFR reading and give an inaccurate measurement? Thanks for any input!
I know there is a belief that the catalytic convertor will effect the lambda values being measured, however under steady state conditions or for example during a normal ramp run on a dyno, the accuracy of the reading isn't affected. You will find that the post cat readings are a little slower in their response to fast transients though.
Here's a useful resource that looks into the cat's effect on AFR - http://www.dtec.net.au/Lambda%20Testing%20Pre%20Vs%20Post%20Converter.htm
Hey Andre,
I had actually come across that link before, the results seemed reasonable. I just was curious as to your experience/methods. Thanks for the input!
