OEM Ecu software?
2632 Vistas
HI all,
Would like to find out if there is any GOOD oem software to remap mainly audi vw ford ECU's.
For instance i have an audi TT 8N with drive by wire i cant connect a after fuel management system,
The drive by wire will go wild and i will get warning lights all day long.
I spoke to our local guys about fitting a aftermarket products and they all say there will be problems.
So now i am asking the professionals what is the best way to make power / remap options.
Kind regards
Dewald
" Forgot to say the TT has T28 upgrade turbo on and 440cc injectors. "
No idea's any one?
I would venture to say that there are multiple companies out there making software to "read/ write" the factory ECU. A few companies to mention would be CMD, Alientech, and so forth. Understand that some of these companies do not have the files defined in the ECU coding. So you would have to go through and decrypt these files. Some companies as well like APR tuning. Already have tuning software and maps ready for purchase.
I bought ECM titanium but dont know if its the best to use to remap.
its very hard to get a map due to bigger injectors turbo ect.
Vipec have a plug-in ECU for the Audi TT. You will have no more problems.
PM me and I will give you a very good price.
As for flashing, best choice will be WinOLS. you can buy map pack from indi vendors.
However, I don't think it is worth the effort if you are doing just the one car.
Regards
Wil
gtihk Whats your email addy?
