Old info on old website
2520 Vistas
Will all the other posts on the other website be on the new website?
Right now the old forum will be archived and available for viewing only. We will at some point migrate the posts to our new forum but this may be a little way off unfortunately. There isn't an automatic or easy way to get this data migrated so it needs to all be done manually which I'm sure you can appreciate is a very time consuming.
I hear ya.. Thanks for the heads up Andre..
Here is the link to the old forums: http://www.learntotune.com/discussions/
Cheers Ben!
It wont let me in
The old forum is only available now for viewing. You won't be able to post in there any longer.
Hiya Andre
It is working now, before when I clicked on General tuning it would not work. But it looks like it is sorted now thanks.
