Old Link G4
1954 Vistas
Hi guys being offered one of the old Link G4 ecu and a new loom. I can seem to find any specs for it. Anyone have any info? I'm building a VR6 turbo engine for my MK2 Jetta. I'm wanting to run sequential ignition and injections just not sure if this has enough drivers. Also guessing there is no support for DBW with it either?
It will depend on specifically which Link G4 ECU you're talking about. As with their current G4+ range, there are a variety of models with different numbers of inputs and outputs.
You're really stretching my memory but I believe the red box G4 Xtreme offered DBW. If you have specific questions on the model you're considering I'd suggest emailing link direct.
