Ongoing problems with tuning EDM Mitsubishi Outlander Turbo - can’t find definition file
3095 Vistas
It’s basically a detuned Evo 8 engine (smaller turbo), I have installed a 3" downpipe and exhaust and spent some time trying to tune it.
Using MMCflash to download and open the ROM-file, ECUflash to modify the tune - but after logging some runs I realised that the definition file I used (for Airtrek Turbo, which is a different ROM) messed everything up. AFR and ignition was off, and the engine was knocking like crazy.
So if anyone can help, I would appreciate it.
ROMID is: C7280010Memory Model: M32176F4
Used to be an open source definition file posted at the ECUflash page, but it’s gone now and nobody is answering support requests:
https://evoscan.com/index.php?option=com_content&view=article&id=165:reflash-2004-2006-mitsubishi-outlander-mh8202f&Itemid=20&dir=%2Fhome4%2Fevoscan%2Fpublic_html%2Ffiles%2Froms%2Foutlanderxml/wklqefdu
Wondering if I should just go with an aftermarket plug-n-play solution, but having a hard time finding a solution for the Outlander Turbo. I guess it wasn’t meant to be tinkered with, or at least not as popular to be tinkered with as the Evos.
Post your ROM file, I will see if I can help.
