PEAK and HOLD amps for stock injectors.
2016 Vistas
Hi all,
I tried searching but couldnt find Peak and hold amps for evo 8 stock 560cc injectors.
Can any one share this data here ?
Thanks.
If I don't have any specific data I use a peak current of 4 amps and a holding current of 1 amp.
Thanks Andre...
Ill try this and see if it works.
Hi andre,
I tried the Peak and hold amps which you mentioned and they worked.
Sadly, ran into Fuel pressure problem so i couldnt do a WOT run.
