Phantom miss issues - 2014 6.2l Jetboat
1889 Vistas
Hi guys, long time stalker, first time poster.
I have a customr who has got a 2014 SS cammed camaro 6.2l Engine in a jet boat. (running mafless)
I did the base tune setup for them as they are more versed in aftermarket Ecus than the E38.
Issue is, they have now had a tuner do the final touch ups on the water but keep having this strange issue that only happens at one load/rpm/tps.
What happens is the engine completely drops torque at around 4400rpm until around 3600ish.
Map remains somewhat stable, Iats stable, Rpm drops steadily, tps commanded and actual remain steady, TAC stays steady. Only thing that tells some sort of story is that the Airmass peals off to 0, and the advance rockets to the first column of the advance table. Always comes back at same RPM.
Things that have been either maxed or mined to suit the jet boat setup that may affect
Knock sensors off, burst off, torque management off, spark ETC and fuel cuts turned off ( to eliminate them being an issue) etc.
We have gone through pretty much everything and cant seem to see whats causing it!
Any help would be much appreciated, as their customer is getting frustrated as expected
Attached is tune file and also one log that you can see the issue at end. i have other logs he sent me that show it happening more often however they are missing some PIDs like Airmass so hard to cross reference
  • JT460-LS3-Delphi-Cams-misfire-fix4-v2.hpt
  • misfire-test-3-v2.hpl
Hello sorry i cannot see from the log when it is doing it at what point (time ) in the log is it doing the issue all I can see is the rpm following the tps approx
Regards Ross
Sorry, it does it at the 3.00 minute mark
Can supply more logs of it doing it more often. However airmass and a few other vital pids are missing.
