Pin assignment for AEM V2
1894 Vistas
Hey all,
Trying to setup this AEM V2. I am finishing the setup of sensors and base calibration.
How do I tell the software which input pin the Oil and Fuel Sensors will be wired/pined to? On the Infinity it had the pinout wizard which would tell you what pins were available and let you assign them.
How do you assign pins on the V2? I do have the pinout guide from the AEM V2 box I am using (Honda Box that is modified for the JZA70 Supra)
Thanks!
Trevor
