PLEX knock monitor v2 - Knock sensor replacement
2440 Vistas
It's unfortunate but I can not find my knock sensor, I have to look for a replacement.
I've seen on some websites they are sold for 70-80USD (what?).
Since I remember it's a Bosch, I guess I can find a replacement (maybe cheaper?) and not waiting for a couple of weeks for it to arrive.
Any advice is welcome.
Thank you
i have seen them on ebay also for about $55 USD part number 0261231045
Plex uses the newer connector style. Part number of the plex supplied sensor is 0261231173 - or at least used to be when I owned one.
I wrote to Plex support when I wanted spare sensors. They said I could use these Bosch P/N with no problems :
0261231045 - I use this one
0261231006
