RB25DET KNOCK LIMITED?
2080 Vistas
Hey guys anyone out there with experience tuning rb25det. Are they a knock limited engine or can you normally tune to MBT. I know every case is going to be different but just after people experinces tuning the rb25
What fuel and which ECU and trigger system will you be using?
In stock form and on pump gas these engines are knock limited in my experience.
