Recommended software and hardware for a beginner
2010 Vistas
Hi!
As the title says, what is the recommended tools to start flashing and programming? And what is the most user friendly? :)
It may be a wise move to also check if they're compatible with the vehicle(s) you are thinking of working on?
Yes, it will mainly be VAG group both diesel and gasoline ;)
