Requesting Base Map for 1jz VVTI on Link StormX Ecu
1438 Vistas
Hello there,
I was wondering if anyone had a good starting base map for a stock 1jz GTE vvti with 264 cams and 1000cc fid injectors. Setup is running stock ct15 turbo with upgraded steel wheel. I'm expecting it should maybe be in the mid 300's possibly on our dynocom dyno.
Will the base map link provides for the jxz100 work sufficiently as well?
