RKRV: PREAMBLE 1 NO RESPONSE
1457 Vistas
Hi, I'm starting in the world of tune, I try to make a reflash in my Subaru WRX 05 USDM, and I get this error when trying to read the ECU. I am using EcuEdit, I connect the green wires to enter test mode, the white connector and the tactrix openport 2.0. I would like to know what I am doing wrong. regards
P.D. Sorry my bad english.
From a quick google on this it looks like you may need to select the Subaru DBW 32 bit template to read from that ECU. Can you try that and maybe post up a screen shot of the actual error message.
