Romraider data logger
3932 Vistas
I'm taking my first steps in tuning, I have a Subaru WRX that I want to tune using all the knowledge I acquired in the HP academy
courses.
I have the Tacktrix OP 2.0 and I us able to read and write the ecu using ecuflash.
I want to use the Romraider logger and make some data log files, But the logger was unable to connect to the ecu.
It seems that the OP doesn't get a com port so the logger cant connect to the ecu.
has anyone encountered this problem?
Have you managed to read the file from the ECU yet?
Have you got all the correct drivers installed?
