RomRider with Coob
1409 Vistas
Hello guys! I have a question, I searched the forum and didn't find anything about it. Coob software is no longer running TGV delete and cat delete, so I was wondering if it is possible to perform these deletes with RomRider and use Coob for ECU Tuning? Anybody know? You tried? Thanks!
Hello,
You cannot use Cobb and Romraider on the same ECU at the same time. If you delete the codes with Romraider, then connect a Cobb, it will revert back the ECU to stock before "marrying" the Cobb. All the changes made with Romraider will be discarded.
Also, you won't be able to flash an ECU when there is a Cobb married to it, except by the said Cobb. You'll get an error when you are flashing the ECU.
Thank you so much Frank. I thought that could happen I just want to make sure.
