Scanning an ECU
1371 Vistas
When I scan my ECU to make changes to my tune, does it actually pull the info out of the computer, or does it just copy it to the HP tuners software
Sorry for the late reply here. The parameters that are scanned on the VCM Scanner software are simply broadcast from the ECU to the OBD2 port.
