Sea doo brp rxt x 300 going into limp mode
115 Vistas
I have a 2021 sea doo rxtx 300 im tuning with an hp tuners mpvi4. I pulled the stock tune and saved it. I then made an alternate version that removes the speed limiter and gave the ve table a little bit of fuel as a starting point for the mods i have (air cleaner, through hull exhaust, waterbox, upgraded boost hoses with bov, intake mabifold upgrade, and oil catch can. Esentially bolt ons. Anyways when i flashed the new tube into the vehicle and tried to test ride it it went straight to limp mode. I'm thinking it has to do with the exhaust manifold sensor calibration. Any helo would be greatly appreciated. Thank you in advance.
