Sequential injection ignition on SR20VE
2226 Vistas
Want to switch a SR2OVE waste spark ignition to sequential.. the car has 32-1 trigger wheel setup on it without cam sensor... and I was wondering how some of you guys have done the conversion from dizzy.... If Andre also can share the setup on the 86... Pics would be also helpful....
You can put a single slot disc in the CAS (such as the AEM one) to use as a sync or various companies make a cam wheel triggers for the SR20 such as Taarks, Mazworx, Ross Performance etc.
Thanks for info Adam... I'll take a look on them....
