Setting up knock threshold maps...
2005 Vistas
Hi,
Trying to set up knock threshold maps on the haltech platinum pro ecu.
If there are any examples out there for someone who may have done the same, guidance would be appreciated.
WEBINAR number 57 = Haltech knock control.
I used the Link webinar on the same subject to learn how exactly to set it up in Linkecu
Thanks - thought that references the eilte series, i'll see what i can apply for the platinum pro version
Hi Rudy, unfortunately the knock control in the Platinum series was quite basic in comparison to the Elite - in reality it was more like noise control than knock control and at least in my experience was not useful.
