Setting which Wideband Closed Loop Lambda uses in Link G4+
2612 Vistas
I have two Widebands on my LS3, one for each bank, and was wondering how to tell the ECU which wideband i want it to use for CLL? I don't want it to use both as i know one is not reading correctly at the moment.
By default it will use the average of all connected Lambda sensors for CLL. If any read zero then they will be ignored.
What ECU and wideband devices do you have? There maybe a couple of other options to force it to use a specific sensor depending on what we are dealing with.
It is a link G4+ Xtreme and two aem X series on canbus
