Short pulse width adder
4320 Vistas
Hi
Andre just want to know is i want to use this data on haltech ecu. what table do i need to use to put this data on haltech software
Thank you
what version/model of the Haltech ECU are you using?
Hi there
i am using Haltech PS1000,PS2000, PRO PLUG IN ECU
Thank you.
Unfortunately full injector characterisation isn't implemented in the Platinum Sport ECU range. You only have the ability to set the injector flow vs MAP and reference fuel pressure.
