Siemens Deka 60s Deadtime values
2496 Vistas
Hi,
Does anyone have accurate deadtime values for Siemens Deka 60s
Part #107961
If possible I’d like to see Deadtime values for 6, 7, 8, 10, 12, 14, 16, & 25volts
For 3bar, 3.5bar, and 4bar.
Thanks in advance!
I have for 550s if you want something close....
Or you can contact directly FiveO motorsport for assistance.
Five O motorsports had exactly what I needed! Thank you Lewis!
Your welcome buddy
Hi Tye,
Are you able to post the dead time values that you ended up using for these injectors (107961)? I’ve found 3 conflicting charts on the internet - not sure which values are the correct ones.
Cheers Lucas
