Start up tune
2310 Vistas
For initial start up tune, will it affect the rest of the tune? Like my rx8 has a good tune after it has fired up and running.
Could you try rephrasing your question? It's as though you've posted part of a conversation that's totally out of context on it's own
Are you referring to just the startup fueling and idle areas of the map?
