stock honda h22 injectors
3161 Vistas
what is around the maximum fuel pressure a stock honda preferable h22A injector can take, and what is best pressure for atomization on performance car around 210whp all motor
Hi Curtis the stock injector can take about 80psi but the flow will be reduced as pressure goes above about 60 psi at a guess and then injector dead times will also be needing to be tested to ensure they are matched to the correct fuel pressure and voltage,
what is your reason for the question are you wanting to save money on larger injectors? because there are other oem injectors that could fit and are larger
flow rates without increasing the fuel pressure
regards Ross
