Syvecs EMAP input choice
1467 Vistas
Hi guys, I'm wiring two EMAP sensors into a Syvecs v8 twin turbo setup and I don't see any EMAP, Exhaust Backpressure, or Turbine Inlet Pressure options under defined sensors. I know I can setup a custom sensor input, but I figured they'd have that and I must be missing it. Is there one typically used that I am not seeing? Thank you!
