syvecs s6plus error
1936 Vistas
Hi, i am trying to setup a supra with DCT transmission on a syvecs s6plus ecu and i'm getting a "slave comms failure" on some sensors and the transmission and i have checked all the wiring, the pin assignment and the sensors and transmission and it should be en working order.
This is first time i'm doing something like this so not sure what i am doing wrong, anyone who can help ?
cheers. :)
I'd strongly recommend that you contact Ryan at Syvecs for help with this. It's a pretty specific system and he knows it inside and out.
ok thanks for your reply. :)
