Timing Corrections
1587 Vistas
I’m reviewing my data logs for my stock map and noticed there are timing corrections at low rpm and high load. I’ve looked through my tables and can’t see why timing is being pulled. Knock sensor voltage is 0, torque limits are 0. I would appreciate your feedback on the possible reasons timing is being pulled. Please find my datalog below:
[url=https://bootmod3.net/log?id=645520a8d10b439e135c7c46]https://bootmod3.net/log?id=645520a8d10b439e135c7c46
