Torque Optimisation
1771 Vistas
Hello andre, is it possible to do torque optimisation with the tuning software is just a flash tune?. Any faster way to do so rather then doing ramp runs? Hope all is well
jaime
Hello Jamie
are you using a dyno or road tuning
road tuning it is pretty hard to do
dyno tuning makes it easy if the dyno can hold at a steady state and altering the ignition in two deg increments when flashing it is never a fast exercise
experience will grow on where to start for different types of engines over time
Regards Ross
