Toyota 4EFTE Trigger setup
2278 Vistas
Hi... need some advice on setting up the trigger for a Toyota 4EFTE engine with its stock distributor being used for trigger signals. Is the setup on the maxxecu file attached correct?
Toyota VR sensors are notoriously difficult to work with in the aftermarket ecu space, you will likely have to find the settings that work best in your specific setup as it can depend on a multitude of factors
