Toyota LS400 1uz fe vvti Engine
3218 Vistas
I'm working on this toyota ls400 1uz engine , and I'm having difficulties removing the rev/rpm limiter. Can anybody help me with this ?
Any suggestions?
What ECU / software are you using?
What have you mechanically changed to allow increasing the rev limit?
