TPS for new Link Monsoon X setup
1928 Vistas
I am finalising the purchase a Monsoon X to be wired to a Totoya 3SGE beams red top engine. Will i be able to connect the Beams OEM throttle position sensor to the link and calibrate it? Or will I need to replace the TPS with the one from link?
Hello the link will certainly be able to use the factory sensor with no issues at all, and the calibration is very simple
Thanks for the prompt reply Ross
