Trigger err
1712 Vistas
Hi all
I'm using Link Mosoon G4+ and i have noticed recently, trigger err counter 2.
err counter 2 is it normal or there is any serious issue with trigger?
the trigger err counter 2 what could be the reason ?
You'll often find that the trigger error will increment during initial startup/cranking as the ECU synchronises. It's not uncommon to see 1-2 errors. What you want to avoid is a situation where the trigger errors continue to increment, particularly at high rpm.
Thanks for the reply Andre.
It is showing only counter 2 only even higher RPM.
thanks for the best support
