trigger setup mitsubishi evo
2404 Vistas
im using emu black on my evo 6 but when im setting up the trigger i dont see any specific setting for the evo
the setting im using are
toothed wheel with 2 missing for crank
the engine runs but just want a second opinion as to the best way setting up the triggers
There is a trigger mode in the EMU Black for MX5/Mitsubishi which is the one you should be using.
