Trying to spec an ignition coil
1784 Vistas
Hi,
I have a project going where I need to spec an ignition coil.
It's a turbo charged 5 cylinder engine with a distributor on a motec M130 ECU.
Any recommendations on a specific one please?
I'm in the UK.
Thanks in advance
What did the OEM vehicle use?
I would probably think Bosch Blue coil, or Lucas DLB105 coil would likely be suitable, but you haven't provided much detail about RPM range.
https://www.amazon.co.uk/Bosch-0221119027-Ignition-Coil/dp/B003NDX684/ref=sr_1_1?dchild=1&keywords=bosch+blue+coil&qid=1616172418&sr=8-1
https://www.amazon.co.uk/Ignition-Standard-Universal-Increased-Strength/dp/B08Z88K8WB/ref=sr_1_10?dchild=1&keywords=lucas+DLB105&qid=1616172300&sr=8-10
The M130 can easily drive individual smart COP units. Are they any of those what were used for later versions of your engine that could be fitted?
