Tuning GM oe Ucu,s
1927 Vistas
Hi all , i have been asked by a customer if i can "unlock" a 2016 onwards ecu and allow it to be tuned with a flash tuner.
Anyone got any info ,
cheers Keith
What's the background information? Customer has a completely stock GM vehicle? What engine?
if it is similar to a 2016+ Dodge ECU (used in RAM 1500 e.g.), then the ECU has to be sent in to the guys at Diablo for example. They unlock the factory ECU, so it can be reflashed using HPTuners, Diablo,....
thanks guys , yes its a ram 1500 5.7 hemi 2016 onwards
cheers Keith
